map_suite_android_edition_installation_guide [2015/09/18 06:57] admin [Environment Preparation] |
map_suite_android_edition_installation_guide [2015/09/24 08:57] admin [System Requirements] |
Line 11: | Line 11: | ||
* .NET Framework 4.5 or higher | * .NET Framework 4.5 or higher | ||
* Android 4.0.3 or higher | * Android 4.0.3 or higher | ||
* Xamarin plug-in is not supported by Visual Studio Express editions. | * Xamarin plug-in is not supported by Visual Studio Express editions. | ||
* We can develop With Xamarin Studio on a Mac machine as well. Check following for the detail. | * We can develop With Xamarin Studio on a Mac machine as well. Check following for the detail. | ||
Line 29: | Line 28: | ||
==== Android Deployment ==== | ==== Android Deployment ==== | ||
- | * Set Up Device for Development | + | * Set Up Device for Development <div>This article will discuss how to setup an Android device and connect it to a computer so that the device may be used to run and debug Xamarin.Android applications.[[http://developer.xamarin.com/guides/android/getting_started/installation/set_up_device_for_development|click here]].</div> |
- | This article will discuss how to setup an Android device and connect it to a computer so that the device may be used to run and debug Xamarin.Android applications.[[http://developer.xamarin.com/guides/android/getting_started/installation/set_up_device_for_development|click here]]. | + | |
- | * Xamarin Android Player | + | * Xamarin Android Player <div>This guide will discuss and introduce the Xamarin Android Player, a high performance Android simulator. [[http://developer.xamarin.com/guides/android/getting_started/installation/android-player/|click here]].</div> |
- | This guide will discuss and introduce the Xamarin Android Player, a high performance Android simulator. [[http://developer.xamarin.com/guides/android/getting_started/installation/android-player/|click here]]. | + | |
==== Android Emulator ==== | ==== Android Emulator ==== |
