map_suite_android_edition_features_bug_fixes_change_log [2015/08/20 03:08] 127.0.0.1 external edit |
map_suite_android_edition_features_bug_fixes_change_log [2015/09/14 02:02] (current) admin |
| - | ====== Map_Suite_Android_Edition_Features_&_Bug_Fixes_Change_Log ====== | + | ====== Map Suite Android Edition Features & Bug Fixes Change Log ====== |
| - | {{article rating}} | ||
| =====Version 9.0.0.0===== | =====Version 9.0.0.0===== | ||
| Release date: 06/24/2015 | Release date: 06/24/2015 | ||
| Line 7: | Line 6: | ||
| ThinkGeo.MapSuite.AndroidEdition Namespace: | ThinkGeo.MapSuite.AndroidEdition Namespace: | ||
| - | *Added expire interval to SqliteBitmapTileCache. | + | * Added expire interval to SqliteBitmapTileCache. |
| - | *Added two events to allow user to load large raster for GdiPlusRasterLayer without OOM issue. | + | * Added two events to allow user to load large raster for GdiPlusRasterLayer without OOM issue. |
| - | *Added supports to allow user to switch tile size between 256*256 and 512*512. | + | * Added supports to allow user to switch tile size between 256 * 256 and 512 * 512. |
| - | *Added more logic to filter Google unexpected result return from server. | + | * Added more logic to filter Google unexpected result return from server. |
| - | *Added FeatureSourceMarkerOverlay support. | + | * Added FeatureSourceMarkerOverlay support. |
| - | *Added MapBoxTileOverlay support. | + | * Added MapBoxTileOverlay support. |
| - | *Fixed a bug where the out of memory exception during drawing TileOverlays. | + | * Fixed a bug where the out of memory exception during drawing TileOverlays. |
| - | *Fixed a bug where the map zooms in/out to an unexpected area. | + | * Fixed a bug where the map zooms in/out to an unexpected area. |
| - | *Fixed a bug where the null reference of the Context object. | + | * Fixed a bug where the null reference of the Context object. |
| Line 21: | Line 20: | ||
| - | *Fixed a bug where there are something wrong with parsing the namespace of WMS capabilities file. | + | * Fixed a bug where there are something wrong with parsing the namespace of WMS capabilities file. |
| - | *Fixed a bug where the EcwRasterLayer runs into memory leak exception. | + | * Fixed a bug where the EcwRasterLayer runs into memory leak exception. |
| - | *Fixed a bug where the GetBoundingBoxCore method of MsSqlFeatureSource runs into exception. | + | * Fixed a bug where the GetBoundingBoxCore method of MsSqlFeatureSource runs into exception. |
| - | *Updated the unmanaged Proj4 dependency to the latest version 4.8. | + | * Updated the unmanaged Proj4 dependency to the latest version 4.8. |
| - | *Fixed a bug where ECW file path name is case-sensitive. | + | * Fixed a bug where ECW file path name is case-sensitive. |
| - | *Added a new class of ScaleLinePrinterLayer to print scale lines. | + | * Added a new class of ScaleLinePrinterLayer to print scale lines. |
| - | *Added new class of ScaleTextAdornmentLayer to Map Suite Core. | + | * Added new class of ScaleTextAdornmentLayer to Map Suite Core. |
| - | *Added a new class of ScaleTextPrinterLayer to print scale text. | + | * Added a new class of ScaleTextPrinterLayer to print scale text. |
| - | *Fixed a bug where there are something wrong with initializing the omerc projection. | + | * Fixed a bug where there are something wrong with initializing the omerc projection. |
| - | *Fixed a bug where the Dispose method of UnmanagedProj4Projection runs into exception. | + | * Fixed a bug where the Dispose method of UnmanagedProj4Projection runs into exception. |
| - | *Fixed a bug where selecting LabelPrinterLayer runs into exception. | + | * Fixed a bug where selecting LabelPrinterLayer runs into exception. |
| - | *Fixed a bug where MrsidRasterLayer runs into memory leak problem. | + | * Fixed a bug where MrsidRasterLayer runs into memory leak problem. |
| - | *Fixed a bug where the Jpeg2000RasterSource runs into memory leak issue. | + | * Fixed a bug where the Jpeg2000RasterSource runs into memory leak issue. |
| - | *Fixed a bug where it runs into exception when building the index of KmlLayer. | + | * Fixed a bug where it runs into exception when building the index of KmlLayer. |
| - | *Fixed a bug that the deployed version of WebEddition, MvcEdition, SilverlightEdition and WmsEdition runs into “Unlicensed for runtime” . | + | * Fixed a bug that the deployed version of WebEddition, MvcEdition, SilverlightEdition and WmsEdition runs into “Unlicensed for runtime” . |
| - | *Added new API for changing the color of Grid lines in ScaleBarAdormentLayer. | + | * Added new API for changing the color of Grid lines in ScaleBarAdormentLayer. |
| - | *Fixed a bug where the WmtsLayer runs into exception, as the code of clearing the tile matrix is incorrect. | + | * Fixed a bug where the WmtsLayer runs into exception, as the code of clearing the tile matrix is incorrect. |
| - | *Added support of requesting tiles using UrlTemplate of resource URL in WmtsLayer. | + | * Added support of requesting tiles using UrlTemplate of resource URL in WmtsLayer. |
| - | *Fixed a bug where reading Shapefile runs into exception if the decimal length of DBFColumn is bigger than 15. | + | * Fixed a bug where reading Shapefile runs into exception if the decimal length of DBFColumn is bigger than 15. |
| - | *Fixed a bug where the IsolineLayer runs into exception sometimes when IsolineType is ClosedAsPolygon. | + | * Fixed a bug where the IsolineLayer runs into exception sometimes when IsolineType is ClosedAsPolygon. |
| - | *Fixed a bug where the scales of tile matrix in WmtsLayer on server side are different from the ones on client side. | + | * Fixed a bug where the scales of tile matrix in WmtsLayer on server side are different from the ones on client side. |
| - | *Fixed a bug where KmlLayer runs into exception when loading KML file with the encrypted dlls. | + | * Fixed a bug where KmlLayer runs into exception when loading KML file with the encrypted dlls. |
| - | *Enhancement OracleFeatureSource, only create one assembly instance. | + | * Enhancement OracleFeatureSource, only create one assembly instance. |
| - | *Fixed a bug where the MagneticNorthLineStyle cannot be serialized. | + | * Fixed a bug where the MagneticNorthLineStyle cannot be serialized. |
| - | *Fixed a bug where the drawn tile images are mismatch each other when applying FileBitmapTileCache. | + | * Fixed a bug where the drawn tile images are mismatch each other when applying FileBitmapTileCache. |
| - | *Added more projection support to WMTS besides the support of EPSG:3857 and EPSG:4326. | + | * Added more projection support to WMTS besides the support of EPSG:3857 and EPSG:4326. |
| - | *Fixed a bug where it returns incorrect class breaks if there is only one ClassBreak item in ClassBreakStyle. | + | * Fixed a bug where it returns incorrect class breaks if there is only one ClassBreak item in ClassBreakStyle. |
| - | *Fixed a bug where the GridFeatureSource generates Gridfile with CurrentCulture but Read GridFile with InviriantCulture. | + | * Fixed a bug where the GridFeatureSource generates Gridfile with CurrentCulture but Read GridFile with InviriantCulture. |
| - | *Fixed a bug where the scales of cached tiles are incorrect if OpenStreetMapLayer works with MultiThread mode. | + | * Fixed a bug where the scales of cached tiles are incorrect if OpenStreetMapLayer works with MultiThread mode. |
| - | *Fixed a bug where it runs into exception when initializing the TileCache of OpenStreetMapLayer as null. | + | * Fixed a bug where it runs into exception when initializing the TileCache of OpenStreetMapLayer as null. |
| - | *Fixed a bug where it runs into exception if the readed KML file includes the bool values. | + | * Fixed a bug where it runs into exception if the readed KML file includes the bool values. |
| - | *Fixed a bug where the height of LegendAdormentLayer/LegendPrinterAdormentLayer is incorrect when the ResizeMode is Fixed. | + | * Fixed a bug where the height of LegendAdormentLayer/LegendPrinterAdormentLayer is incorrect when the ResizeMode is Fixed. |
| - | *Fixed a bug where there are something wrong with CodeGenerator. | + | * Fixed a bug where there are something wrong with CodeGenerator. |
| - | *Improved performance of drawing GraticuleAdornmentLayer. | + | * Improved performance of drawing GraticuleAdornmentLayer. |
| - | *Changed the default value of LegendContentResizeMode to Fixed. | + | * Changed the default value of LegendContentResizeMode to Fixed. |
| - | *Fixed bug that WMS don't parse response XML which describe error information. | + | * Fixed bug that WMS don't parse response XML which describe error information. |
| - | *Fixed bug GetWellKnownText for lineshape haven't been convert to Invariant Culture. | + | * Fixed bug GetWellKnownText for lineshape haven't been convert to Invariant Culture. |
| - | *Remove toUpper for whereClause of MsSql2008FeatureLayer. | + | * Remove toUpper for whereClause of MsSql2008FeatureLayer. |
| - | *Fixed a bug where the ClientId and PrivateKey of GoogleMapsLayer doesn't work with SingleTile. | + | * Fixed a bug where the ClientId and PrivateKey of GoogleMapsLayer doesn't work with SingleTile. |
| - | *Improved the GeoCoderGenerator. | + | * Improved the GeoCoderGenerator. |
| - | *Added support of support custom spatial index name in mssqlfeaturelayer. | + | * Added support of support custom spatial index name in mssqlfeaturelayer. |
| - | *Fixed a bug where the request tile size is not equal to the size of map with SingleTile. | + | * Fixed a bug where the request tile size is not equal to the size of map with SingleTile. |
| - | *Fixed a bug where the method GetAllMapShape of KmlFeatureLayer runs into exception. | + | * Fixed a bug where the method GetAllMapShape of KmlFeatureLayer runs into exception. |
| - | *Improved the IsoLine result generated by removing the holes at the center of IsonLine. | + | * Improved the IsoLine result generated by removing the holes at the center of IsonLine. |
| - | *Added the embedded TAB style support. | + | * Added the embedded TAB style support. |
| - | *Fixed a bug where ProjectionFromSphericalMercator property doesn't work. | + | * Fixed a bug where ProjectionFromSphericalMercator property doesn't work. |
| - | *Added Attribution to all layers and Overlays. | + | * Added Attribution to all layers and Overlays. |
| - | *Fxied a bug where the MagneticDeclinationAdornmentLayer runs into memory issue. | + | * Fxied a bug where the MagneticDeclinationAdornmentLayer runs into memory issue. |
| - | *Added the new API SetWellKnownBinary(byte[[]] wkb) to Feature class to allow changing the WKB of the feature. | + | * Added the new API SetWellKnownBinary(byte[] wkb) to Feature class to allow changing the WKB of the feature. |
| - | *Improved the performance of method byte[[]] ShapeFile.ReadPolygon(byte[[]] dataBytes, int startIndex). | + | * Improved the performance of method byte[] ShapeFile.ReadPolygon(byte[] dataBytes, int startIndex). |
| - | *Removed the using JTS in Feature to Shape conversion(BaseShape.FromWellKnownBinary, BaseShape.CreateShapeFromWellKnownData). | + | * Removed the using JTS in Feature to Shape conversion(BaseShape.FromWellKnownBinary, BaseShape.CreateShapeFromWellKnownData). |
| - | *Added enhancements to OpenStreetMapLayer and OpenStreetMapOverlay to make sure the exception can be thrown out. | + | * Added enhancements to OpenStreetMapLayer and OpenStreetMapOverlay to make sure the exception can be thrown out. |
| - | *Added Leader Lines. | + | * Added Leader Lines. |
| - | *Enhanced the Best Placement algorithm. | + | * Enhanced the Best Placement algorithm. |
| - | *Added an Abbreviation Dictionary. For example, add "University" with "Univ" to the Abbreviation Dictionary and "University" will be abbreviated when displayed. | + | * Added an Abbreviation Dictionary. For example, add "University" with "Univ" to the Abbreviation Dictionary and "University" will be abbreviated when displayed. |
| - | *Added Max Nudging parameter to specify how far a label can be moved. | + | * Added Max Nudging parameter to specify how far a label can be moved. |
| - | *The unit for Drawing Margin is now pixels instead of percentage. | + | * The unit for Drawing Margin is now pixels instead of percentage. |
| - | *Geohashing APIs - Allows sorting of GeoFeatures for performance gains. Shapefiles of features that are in proximity are stored on the same section of the disk. | + | * Geohashing APIs - Allows sorting of GeoFeatures for performance gains. Shapefiles of features that are in proximity are stored on the same section of the disk. |
| - | *Standard color access for Geocolors, brushes, and pins has been streamlined. | + | * Standard color access for Geocolors, brushes, and pins has been streamlined. |
| - | *New Projection API to find local UTM Zone for any feature. No longer need to look up UTM Zone manually. | + | * New Projection API to find local UTM Zone for any feature. No longer need to look up UTM Zone manually. |
| - | *Added ability to save and import style files from GIS Editor to Map Suite. | + | * Added ability to save and import style files from GIS Editor to Map Suite. |
| - | *One-way road line style now available. | + | * One-way road line style now available. |
| - | *More filter conditions added for RegEx. It is now simpler to use. | + | * More filter conditions added for RegEx. It is now simpler to use. |
| - | *Added R-Tree Indexing for KML feature layers. | + | * Added R-Tree Indexing for KML feature layers. |
| - | *Gave ability to modify well-known binary on a feature. Now possible to directly access and modify WKB. | + | * Gave ability to modify well-known binary on a feature. Now possible to directly access and modify WKB. |
| - | *Can now add column value data without defining it up front to Map Shapes and Edit Shapes. | + | * Can now add column value data without defining it up front to Map Shapes and Edit Shapes. |
| - | *Added Boundary Solution Parcel feature layer. | + | * Added Boundary Solution Parcel feature layer. |
| - | *Created new APIs for accurate measurements regardless of projection. | + | * Created new APIs for accurate measurements regardless of projection. |
| - | *Enhanced Tile Cache - new APIs allow expiration by size, date, etc. | + | * Enhanced Tile Cache - new APIs allow expiration by size, date, etc. |
| - | *Created Well Known Binary feature layer type for better performance, especially on Android and iOS. | + | * Created Well Known Binary feature layer type for better performance, especially on Android and iOS. |
| - | *New Printing APIs allow switching between page and world coordinates. | + | * New Printing APIs allow switching between page and world coordinates. |
| - | *ScaleBar and ScaleLine - can set a text style to control the font and look. | + | * ScaleBar and ScaleLine - can set a text style to control the font and look. |
