Both sides previous revision Previous revision | Last revision Both sides next revision | ||
map_suite_adornments [2016/01/08 17:06] mwolffer [Logo Adornment] |
map_suite_adornments [2016/01/08 17:09] mwolffer [A Look at the Code] |
Line 83: | Line 83: | ||
=====A Look at the Code===== | =====A Look at the Code===== | ||
- | There are two projects in the Visual Studio solution. One is for the Leaflet javascript mapping library and one is for OpenLayers. In each project the AdornmentsController contains the function that loads each adornment type. The functions show how to build a adornment layer.The RefreshAdornmentLayer function and RefreshSchoolPoiLayer function will show two different drawing styles. | + | There are two projects in the Visual Studio solution; one using Leaflet javascript mapping library and the other using OpenLayers. In each project the AdornmentsController contains the function that loads each adornment type. The functions shows how to build a adornment layer. The RefreshAdornmentLayer function and RefreshSchoolPoiLayer function will show two different drawing styles. |
