The ThinkGeo Wiki is the central and official source of documentation, sample code and learning material for Map Suite users. It contains resources such as API reference, QuickStart Guides to get you started, sample projects with source code you can learn from, change logs for each version, and more.
The wiki's resources are categorized by product, so you can easily find the information you need for the Map Suite products you're working with. The products run on one or more platforms; the key features, which are shared by different products, run on different platforms as well. Please check platform coverage for the details.
For Mobile Platforms
For Desktop Platforms
Build Windows client apps using Windows Forms, running on Windows and Linux/Mac(through Mono).
For Web Platforms
Build REST based web services for JS/HTML5 Web applications. Running on Windows and Linux/Mac(through Mono).
Build traditional ASP.NET Web Forms mapping applications, running on Windows and Linux/Mac(through Mono).
For Server
Find the shortest path between multiple locations, deliver turn-by-turn directions, avoid specified areas
Royalty-free high-level global imagery matched with highly-detailed US imagery.
Reverse-geocoding allows you to match a latitude and longitude location to a street address anywhere on earth.
