main_page [2019/03/04 17:10] sacha [ThinkGeo UI Controls] |
main_page [2020/05/19 16:39] benbai |
Line 46: | Line 46: | ||
=====ThinkGeo UI Controls===== | =====ThinkGeo UI Controls===== | ||
- | ThinkGeo provides feature-rich .NET controls based on different platforms and different technologies. They are available on NuGet, as well as many other ThinkGeo Map Suite NuGet packages which are shared amongst ThinkGeo UI controls which is why you will notice the majority of the APIs sharing common descriptions and samples. Here is a [[map_suite_platform_coverage|platform coverage]] showing what feature package is shared across different products. | + | ThinkGeo provides feature-rich .NET controls based on different platforms and different technologies. They are available on NuGet, as well as many other ThinkGeo Map Suite NuGet packages which are shared amongst ThinkGeo UI controls which is why you will notice the majority of the APIs sharing common descriptions and samples. Here is a breakdown of [[map_suite_platform_coverage|platform coverage]] showing what feature package is shared across different products. |
- | <faicon title-android> <span title-content>[[map_suite_mobile_for_android|Mobile for Android]]</span> | + | <faicon title-android> <span title-content>[[thinkgeo_mobile_for_android|Mobile for Android]]</span> |
Build native GIS apps running on Android devices through Xamarin | Build native GIS apps running on Android devices through Xamarin | ||
Line 62: | Line 61: | ||
- | <faicon title-ios> <span title-content>[[map_suite_mobile_for_ios|Mobile for iOS]]</span> | + | <faicon title-ios> <span title-content>[[thinkgeo_mobile_for_ios|Mobile for iOS]]</span> |
Build native GIS apps running on iPhone® and iPad® through Xamarin | Build native GIS apps running on iPhone® and iPad® through Xamarin | ||
Line 72: | Line 71: | ||
- | <faicon title-wpf> <span title-content>[[map_suite_desktop_for_wpf|Desktop for WPF]]</span> | + | <faicon title-wpf> <span title-content>[[thinkgeo_desktop_for_wpf|Desktop for WPF]]</span> |
- | Build Windows client apps using WPF (Windows Presentation Foundation) | + | Build Windows client for the tranditional .NET Framework |
- | </div> | + | |
- | <div samplelist> | ||
- | <faicon title-winforms> <span title-content>[[map_suite_desktop_for_winforms|Desktop for WinForms]]</span> | ||
- | Build Windows client apps using Windows WinForms. | ||
- | <div newline></div> | ||
- | <faicon title-webapi> <span title-content>[[map_suite_web_for_webapi|Web for WebAPI]]</span> | + | <faicon title-winforms> <span title-content>[[thinkgeo_desktop_for_winforms|Desktop for WinForms]]</span> |
- | Build REST based web services for JS/HTML5 Web applications. | + | Build Windows client for the cross platform framework: .NET Core |
- | </div> | + | |
- | <faicon title-mvc> <span title-content>[[map_suite_web_for_mvc|Web for MVC]]</span> | ||
- | Build web mapping applications using the MVC framework, running on Windows. | ||
- | </div> | ||
- | <faicon title-webforms> <span title-content>[[map_suite_web_for_webforms|Web for WebForms]]</span> | ||
- | Build traditional ASP.NET Web Forms mapping applications. | ||
Line 109: | Line 87: | ||
- | + | <div newline></div> | |
- | =====ThinkGeo SDKs and Offline Data===== | + | |
- | ThinkGeo provides the following Add-Ons and offline data, which are the same ones ThinkGeo Cloud is using. The data can be properly consumed by ThinkGeo UI Controls Offline. | + | |
- | <faicon title-routing> <span title-content>[[thinkgeo_sdk_routing|Routing]]</span> | + | <faicon title-webforms> <span title-content>[[thinkgeo_web_for_webapi|Web for WebAPI]]</span> |
- | Find the shortest path between multiple locations, deliver turn-by-turn directions, avoid specified areas. | + | Build Web apps using Web API |
- | <faicon title-worldstreets> <span title-content>[[thinkgeo_offline_data_maps_streets|Maps Streets]]</span> | + | <faicon title-webforms> <span title-content>[[thinkgeo_web_for_blazor|Web for Blazor]]</span> |
- | Royalty-free worldwide vector data ready to use in your application. | + | Build Web apps using Blazor |
- | </div> | + | |
- | <faicon title-maps-imagery> <span title-content>[[thinkgeo_offline_data_maps_imagery|Maps Imagery]]</span> | ||
- | Royalty-free high-level global imagery matched with highly-detailed US imagery. | ||
- | </div> | ||
- | <faicon title-geocoding> <span title-content>[[thinkgeo_sdk_geocoding|Geocoding]]</span> | ||
- | Convert US addresses to coordinates and vice-versa | ||
- | </div> | ||
- | <faicon title-reverse-geocoding> <span title-content>[[thinkgeo_sdk_reverse_geocoding|Reverse-Geocoding]]</span> | ||
- | Reverse-geocoding allows you to match a latitude and longitude location to a street address anywhere on earth. | ||
- | </div> | ||
- | <faicon title-elevation> <span title-content>[[thinkgeo_sdk_elevation|Elevation]]</span> | ||
- | Get the elevation of a point on the earth. | ||
Line 159: | Line 110: | ||
=====ThinkGeo Open Source===== | =====ThinkGeo Open Source===== | ||
- | ThinkGeo provides following open Open Source libraries, all available on Github. | + | ThinkGeo provides the following open Open Source libraries, all available on Github. |
<faicon title-vectormap> <span title-content>[[thinkgeo_vector_map_javascript_library|VectorMap.js]]</span> | <faicon title-vectormap> <span title-content>[[thinkgeo_vector_map_javascript_library|VectorMap.js]]</span> |
