thinkgeo.mapsuite.core.style
ThinkGeo.MapSuite.Core.Style
This abstract class is the root for all styles used for drawing features.
Style()
  • This is the default constructor for the style and should be called by inherited classes.
CloneDeep()
  • Create a copy of style using the deep clone process.
  • The difference between deep clone and shallow clone is as follows: In shallow cloning, only the object is copied; the objects within it are not. By contrast, deep cloning copies the cloned object as well as all the objects within.
  • Type:Style
  • Description:A cloned style.
  • This method draws the features on the canvas you provided.
  • This method is the concrete wrapper for the abstract method DrawCore. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Description:None
  • features
    • Type:IEnumerable<Feature>
  • canvas
    • Type:GeoCanvas
  • labelsInThisLayer
  • labelsInAllLayers
  • This method draws the shapes on the canvas you provided.
  • This method is the concrete wrapper for the abstract method DrawCore. In this method, we take the shapes you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each shape differently. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Description:None
  • shapes
    • Type:IEnumerable<BaseShape>
    • Description:This parameter represents the shapes you want to draw on the canvas.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter represents the canvas you want to draw the shapes on.
  • labelsInThisLayer
  • labelsInAllLayers
GetRequiredColumnNames()
  • This method returns the column data for each feature that is required for the style to properly draw.
  • This method is the concrete wrapper for the abstract method GetRequiredColumnNamesCore. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore we read that property and add it to the collection. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Type:Collection<String>
  • Description:This method returns a collection of column names that the style needs.
  • This method draws a sample feature on the canvas you provided.
  • This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Description:None
  • canvas
    • Type:GeoCanvas
DrawSample(GeoCanvas)
SaveStyle(String)
  • filePathName
SaveStyle(Stream)
  • stream
    • Type:Stream
LoadStyle(Uri)
  • Type:Style
  • styleUri
    • Type:Uri
LoadStyle(Stream)
  • Type:Style
  • styleStream
    • Type:Stream
CloneDeepCore()
  • Create a copy of style using the deep clone process. The default implementation method uses serialization.
  • Type:Style
  • This abstract method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:None
  • features
  • canvas
    • Type:GeoCanvas
  • labelsInThisLayer
  • labelsInAllLayers
GetRequiredColumnNamesCore()
  • This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore we read that property and add it to the collection.
  • This virtual method is called from the concrete public method Draw. In this method, we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area. When implementing this virtual method, consider the canvas size and draw the sample image appropriately. You should keep in mind that the sample typically shows up on a legend.
  • Description:None
  • canvas
    • Type:GeoCanvas
This property gets and set the name of the style.
IsActive
This property gets and sets the active status of the style.
RequiredColumnNames
This property gets the collection of fields that are required for the style.
Filters
FiltersCore
thinkgeo.mapsuite.core.style.txt · Last modified: 2017/03/16 21:59 (external edit)
