Map Suite Web Edition Features & Bug Fixes Change Log
From ThinkGeo Wiki
| Rate This Article | |
| Current rating: 0% (0 votes)
You need to enable Javascript to vote
Contents |
Version 6.0.0.0
Release date: 05/14/2012
ThinkGeo.MapSuite.WebEdition Namespace:
- Fixed an issue while a cached overlay does not line up properly after panning or zooming in/out.
- Added the Culture Info support to ManagedProj4Projection.ConvertProj4ToPrj() method.
- Fixed an issue where AdornmentOverlay doesn't work well if map is not placed at left-upper corner.
- Fixed an issue where CloudPopup cannot be corrected closed when there are more than one map controls on the page.
- Fixed an issue where an exception is thrown if ID Value is not passed through OpenStreetMapOverlay's constructor.
- Fixed an issue where the map disappears when resizing the Safari browser.
- Added the Opacity support to Popup.
- Fixed an issue where PanZoom's GlobeButton cannot be disabled.
- Fixed an issue where pointstyle is improperly displayed when exporting to pdf.
- Fixed an issue where BingMapsOverlay cannot be set as ActiveBaseOverlay.
- Fixed an issue where map is jumpy while Panning on the boundary of a Restricted Extent.
- Added the support of Map Quest on Client Side.
- Fixed an issue where the context menu disappears after a flash at high zoom levels.
- Fixed an issue where Context Menu is not showed up at the position where mouse clicked.
- Fixed an issue where an exception is thrown in OnClientDoubleClick event.
- Added Google Map's StreetView to GoogleMapOverlay
- Added Bing Maps Logo and data provider attribution to BingMapsOverlay
- Fixed an issue where the tiles of LayerOverlay shift while using ServerCache.
- Fixed an issue where a popup is prompted up while loading the GoogleMaps.
- Fixed an issue where current extent get lost after postback.
- Fixed an issue where the client layer.redraw(true) doesn't work for InMemoryMarkerOverlay and FeatureSourceMarkerOverlay.
- Fixed an issue where changing the PanZoomBar visibility on mobile browsers take no effect.
- Fixed an issue where cache tiles shift after loading.
- Added Google Map's TrafficView to GoogleMapOverlay
- Fixed an issue where BingMaps in Chrome or Safari, turns to white after switching between different overlays.
- Added New Web Request Events and Methods
- Fixed an issue where certain styles don't call the GetRequiredColumnNames for child styles.
- Fixed an issue where GeoTiffRasterLayer’s HasBoundingBox always returns true.
- Implemented GeometryCollection.GetDitanceTo() method.
- Fixed an spelling issue, rename "Dragable" to "Draggable"
- Added the ability to use custom servers in OpenStreetMaps.
- Added the support of Nautical Miles to ScaleBarAdornmentLayer.
- Fixed an issue where the first feature is always removed when deleting multiple features in MsSql2008FeatureLayer.
- Fixed an issue where an exception is thrown in PrinterGeoCanvas.DrawTextCache method when RotationAngle is not 0.
- Improved the Exception Description in FeatureSource.GetAllFeatures method
- Added the implementation of PostgreSqlFeatureSource GetFeaturesByColumnValueCore.
- Fixed an serialization issue where the keys to a GeoCollection were not being added back correctly when de-serializing.
- Fixed an spelling issue, rename GoogleMapZoomLevelSet to GoogleMapsZoomLevelSet.
- Fixed an issue where shapefile's bounding box is not updated after removing a feature.
- Fixed an issue where multi features cannot be correct deleted at the same time.
- Fixed an issue where ShapeFileFeatureSource.GetBoundingBoxById() doesn't call GetFeaturesByIdsCore() internally.
- Improved the creating shape performance by moving some logic from BaseShape constructor to property.
- Removed the TabFeatureLayer from FdoExtension as we've added it in MapSuiteCore.
- Fixed an issue where WorldMapKitLayer couldn't export to Pdf by using PdfExtension.
- Fixed an issue where an exception is thrown in BingMapsLayer when zooming to an area where no imagery is available.
- Added Clear() method into InMemoryFeatureLayer and InMemoryFeatureSource.
- Improved the performance of MsSql2008FeatureSource GetBoundingBox
- Fixed an issue where files with big case ".SHP" extension are not accepted.
- Added the support of WMS 1.3.0.
- Fixed an issue where PagePrinterLayer automatically changes the orientation..
- Added StreamLoading event to GridIsoLineLayer
- Upgraded all the 3rd part DLLs referenced to the latest version
- Fixed the issue where the features returned by GetFeaturesInsideBoundingBox shouldn’t contain the ones removed.
- Improved the map object XML Serialization.
- Improved Speed Improvements by introducing MapSuite WicBitmap extension.
- Added the support of Layer Transparency.
- Improved the Memory Usage for ShapeFileFeatureSource.
- Upgraded MrSid & Ecw to the latest version.
- Improved drawing performance.
- Added the support of Code Generator.
- Fixed the issue where the "out of memory" exception is thrown when loading a large .tiff image.
- Improved the drawing quality of TiffRasterLayer by optimizing the reading logic
- Improved Label Formatting by adding Formatting and Formatted events to TextStyle.
Version 5.5.0.49
Release date: 12/31/2011
- Fixed an issue where the OpenStreetMapOverlay constructor doesn't hold the passed parameters.
- Fixed an issue that the cache doesn't work properly.
- Fixed an issue where a popup is added multiple times.
- Fixed an issue where Server.Transfer redirects to the wrong page.
- Fixed an issue where an overlay in meter based projection with cache enabled doesn't match other overlays.
- Fixed an issue where the PrinterDocument is disposed after raising the PrintPage event.
- Fixed an issue where an exception is thrown when the tiff image is zoomed out to one pixel.
- Fixed an issue where the rtreeIndex cannot be correctly used in ShapeFileMultiFeatureSource.
- Fixed an issue where an SQL exception is thrown when executing a SQL statement with "where" clause within it in MsSql2008FeatureLayer.
- Fixed an issue where the bounding box is incorrect after removing a feature from a shapefile.
- Fixed an issue where Bing Maps Layer shifts after zooming in.
- Fixed an issue where LineShape.GetLineOnALine doesn't work properly.
- Fixed an issue where the MapPrinterLayer constructor doesn't hold the passed parameters.
- Fixed an issue where GeoCanvas.DrawCircle method is using the wrong coordinate unit for width and height.
- Fixed an issue where OpenStreetMapLayer doesn't display properly on the border.
- Fixed an issue where ArgumentOutOfRangeException is thrown when calling SpatialQuery method on a projected Layer.
- Fixed an issue where the first features is always deleted when deleting features..
- Fixed an issue where GetLineOnALine sometimes returns null.
- Fixed an issue where GetFeaturesInsideBoundingBox doesn't work properly for point based shape file.
Version 5.5.0.0
Release date: 11/14/2011
- Fixed an issue where it throws the JS exception "html:invalid operation" if the map is in Updatepanel
- Fixed an issue where the EditOverlay runs into error when deserializing its features.
- Fixed an issue where hover popup doesn't work properly in IE9.
- Fixed an issue where PopUpDelay doesn't work for ClusterMarkerStyle.
- Enhanced BingMapsOverlay making it support Enterprise Key.
- Fixed an issue where the layers on the Overlay switcher are disordered.
- Fixed an issue where Properties Window and Map Control keep Flashing or Continuously updating in Design Time.
- Enhanced the LayerOverlay so the TiledWmsLayer requests images simataneously.
- Fixed an issue where drawing a Label on a Marker increases image size.
- Fixed the way that the "Number of Points must be 0 or > 3" exception is handled.
- Fixed an issue where PointType.Cross in PointStyle doesn't work properly.
- Enhanced the documentation for OSM layer and overlay.
- Fixed an issue where ScaleBar.AreaStyle doesn't draw properly.
- Fixed an issue where an exception is thrown when Multipolygon.Contains method is called.
- Enhanced the exception description where a single Tab file is loaded without other related files.
- Fixed an issue where GettingZoomlevelsForDrawing doesn't work well when custom levels are overlapped.
- Changed the "URI" to "WebRequest" property in SendingRequestUriTileEventArgs Class for all the products.
- Fixed an issue where ShapeFileFeatureSource.CloneDeepCore() didn't work well with dBaseEngine.
- Added MaxRecordsToDraw property to FeatureSource and FeatureLayer.
- Fixed an issue where GraticuleAdornmentLayer doesn't work properly.
- Fixed an issue where IndexPathFileName is not updated when ShapePathFileName property is changed.
- Added the IsoLine Support.
- Created a Print layout system.
- Fixed an issue where the polygon shapes are not loaded correctly if the first ringShape in a polygon feature in shape file is not the outer ring.
- Fixed an issue where GetFeatureNestestTo returns wrong result.
- Fixed an issue where EditTools.ScaleUp and ScaleDown doesn't work for line shapes.
- Fixed an issue where TabFeatureLayer doesn't display properly with Projections settings.
- Fixed the issue where an exception is thrown when calling GetLineOnALine with the same start and end points.
Version 5.0.0.55
Release date: 7/7/2011
- Fixed a bug where the fontstyle didn't support two different styles together
- Fixed a bug where ServerCache created multiple folder for single zoomlevel
- Fixed a bug Where Visual Studio 2010 became unresponsive after debugging several times
- Fixed a bug where the GeometryCollection can't be displayed correctly with Projection
- Fixed a bug where the image size setting had no effect
- Enhanced method GetPointOnALine in LineShape
- Fixed a bug where the first point of DotDensityStyle wasn't random when using multiple DotDensityStyles
- Enhanced MsSql2008FeatureSource to support Open/Close connection only once
- Fixed a bug where Legend LineItem images and text didn't aligned on some systems
- Fixed a bug where TabFeatureLayer Spatial query returned wrong featureID
- Enhanced the logic for method GetLineOnALine in LineShape
- Fixed a bug where an exception was thrown while loading tab file based with index.
- Fixed a bug where MultipleShapeFileFeatureLayer constructor parameteres are useless
- Fixed a bug where BuildIndexMode had no effect while building index file of Tab file with DoNotRebuild mode
- Enhanced the load performance for tab file when using index file
- Enhanced the logic in GetLineOnALine
- Fixed a bug where CloneDeep method in TabFileFeatureLayer class didn't work as expected
- Fixed a bug where the ValueStyle didn't work as expected on TabFileFeatureLayer
- Fixed a bug where invalid validation of wms crs existed while checking WmsRasterLayer.
- Fixed a bug where an exception was thrown while serializing MsSql2008FeatureLayer.
- Enhanced the drawing order for features in layer
- Fixed a bug which is related to location calculate problem in GdiPlusGeoCanvas
- Fixed a bug where method GetBoundingBox thrown exception on MsSql2008FeatureLayer if some of the features are null
Version 5.0.0.0
Release date: 5/16/2011
- Fixed a JScript runtime error on AutoRefresh.
- Fixed a bug where the sequence in the overlay switcher doesn't match the sequence of the overlays.
- Fixed a bug in the Marker Roatation sample.
- Fixed a bug that a JavaScript error in Geo_Resource.axd when using Google Overlay.
- Fixed a bug where the ContextMenu doesn't display within the Master Page or User Control.
- Fixed a bug where overlays disappeared when panning, zooming under a different projection.
- Fixed a bug when assigning rotation angles to markers.
- Fixed a bug where an error is thrown from Map click/double-click and Highlight Overlay click event while the map is loading.
- Fixed a bug where a JavaScript error was thrown when one of multiple maps were hidden.
- Upgraded to OpenLayers2.10
- Added support iOS touch events including pinch zooming, drag panning etc.
- Obsoleted ClientZoomLevelScales property and SyncZoomLevelScales method, but added ZoomLevelSet property instead.
- Added a way to turn off WMS Background Layer on the server side.
- Upgraded the Google API to support versions V2 and V3.
- Added a new item called DegreesMinutesSecondsLatitudeLongitude to the ThinkGeo.MapSuite.WebEdition.MouseCoordinateType enumeration.
- Fixed an issue where an exception was thrown when adding two styles with the same column name except the case was different.
- Fixed a bug where the result was not complete in the MultipleShapefileFeatureSource.GetFeaturesNearestTo() method.
- Fixed a bug where the TileCache result was not always correct when using a projection.
- Fixed a bug where the GetInternalGeographyUnit always return Unknown when using FeatureSource.GetFeaturesWithinDistance with the RotationProjection.
- Fixed a bug where the UserID doesn't be set in the constructor of OracleFeatureSource/OracleFeatureLayer.
- Fixed a bug where the DrawingLevel could not be set for an IconStyle.
- Fixed a bug that the GetLineOnLine method doesn't work correctly for some cases.
- Fixed a bug where the map was not displayed correctly when using GdiPlusRasterLayer.
- Fixed a bug where Feature.Equals method didn't always work correctly.
- Fixed the issue where the GraticuleAdornmentLayer blocks when its projection's internal and external parameters are the same.
- Fixed the issue where an exception was thrown when calling GetBoundingBox in MsSqlFeatureSource which only had one feature.
- Fixed the issue where the map was not displayed properly when using GoogleLayer as background with different DPIs.
- Fixed a bug in MultipleFeatureLayer where GetFeatureById returned a wrong feature.
- Fixed a bug where an exception was thrown when zooming out too far for geotiff raster layers.
- Fixed the issue where the ClientId and PrivateKey properties wouldn't work in the Google Maps Layer.
- Fixed a bug where the Column.MaxLength is not correct when opening a database view with MsSQL2008FeatureLayer.
- Fixed the bug that the result if not correct for GetBoundingBox method in WmsRasterLayer.
- Fix a bug where the image had a one pixel offset while using WMSRasterLayer.
- Fixed the issue where the GetDistanceTo method returns the same result no matter what the DistanceUnit was.
- Fixed a bug where the GeometryCollectionShape could only be displayed when three default styles where set.
- Fixed a bug where "null object reference" exception was thrown when using AllowLineCarriage=true.
- Fixed a bug where the GeoTiffRasterLayer threw an exception when passing in a rectangle shape instead of a world file.
- Fixed the issue where the GoogleLayer would not overlap with a given shape file in some zoomlevels.
- Fixed the issue that FDOExtensionX64 didn't work in .net 4.0 framework.
- Fixed a bug in the InMemoryFeatureLayer.Update which caused it to fail in some cases.
- Fixed the issue where a wrong Geography Unit was used within GetFeaturesWithinDistanceOf when the projection was set.
- Fixed a bug where the AreaStyle didn't work properly in the CustomStyles collection when the feature count was less than ten.
- Fixed a bug where the value of the Tag property is lost when assigning a BaseShape to a Feature.
- Fixed a bug that the result of GetLineOnALine is not correct for some cases.
- Fixed the issue where some features had fewer points than they should using the DotDensityStyle.
- Fixed the issue where the GeoLinearGradientBrush might draw incorrectly.
- Fixed a bug where DrawWorldImageWithoutScaling didn't work correctly when passing in a rotation angle.
- Fixed a bug where the TabFeatureLayer in the previous FdoExtension could not be serialized.
- Fixed the bug in GetLineOnALine where the first and last vertex has the same coordinates.
- Added the static method GenerateGrid() in the GridFeatureLayer to create grid files.
- Modified the validator to allow the user to use unstandard crs.
- Improved the exception descriptions for Oracle, Sql2008 and Postgre layer.
- Added an constructor which accepts an image in LogoAdornmentLayer class.
- Set an alias when a dbf has duplicate column names.
- Added support for more types of GeoTiff files.
- Added properties in FdoFeatureLayer to make them consistent with the constructor parameters..
- Added validators to ZoomLevel.Draw method to check if input features are empty.
- Added Methods GetWGS84ParametersString, GetDecimalDegreesParametersString and GetLatLongParametersString to ManagedProj4Projection, UnmanagedProj4Projection and Proj4Projection.
- Added ShapeFileReadWriteMode property to the ShapeFileFeatureLayer.
- Enhanced TiledWmsLayer to support more than one server url as input.
- Fixed a bug where the ScaleLine didn't refresh properly during panning.
- Fixed a bug that memory usage would increase when using Projection.
- Added a way to build nice looking legends using the LegendAdornmentLayer.
- Supported projection for GeometryCollectionShape.
- Updated EPSG list from the Proj4 website.
- Added a validator to handle the exception when passing in an empty collection of features to the ZoomLevel.Draw.
- Enhanced exception description for the RtreeSpatialIndex.
- Fixed the issue where the GeoPen.Brush only worked for the GeoSolidBrush.
- Enhanced the way of using StreamLoading event in GdiPlusRasterSource.
- Supported conversion of .PRJ files to and from PROJ4 strings.
- Fixed a problem where the polygon GetCenterPoint returns NaN for some case.
- Added an event in GoogleMapsLayer which passes out the request url.
- Updated the GetGeographyUnit methods and remove unused GetXXXParameters methods.
- Added a GeographyUnit property to the RotationProjection.
- Added a way to get the bounding box from the world file class.
- Added support for the 64 bit version of FDO.
- Marked ManagedGeoTiffRasterSource Serializable.
- Added a new API to create a simple MsSqlServer table.
- Fixed a bug where the GetLongitudeDifferenceFromDistance didn't work correctly when very small values were used as inputs.
- Added BingMapsLayer and BingMapsZoomLevelSet.
- Added new overload constructor Feature(wellKnownText, id, columnValues) to Feature.
- Added GraticuleAdornmentLayer class.
- Added Height, Width and BackgroundMask properties to AdornmentLayer.
- Added AlternateBarBrush property to ScaleBarAdornmentLayer.
- Added DrawingQuality enum to GeoTiffRasterLayer.
- Marked [Serializable] for GeoTiffRasterLayer, HeatLayer, GraticuleAdornmentLayer and HeatStyle.
- Added overloads for GetFeaturesNearestTo at QueryTools to be the same as the FeatureSource.
- Exposed InterpolationMode for GdiPlusGeoCanvas and GdiPlusRasterLayer.
- Added a StreamLoading event to the GdiPlusRasterLayer and ShapeFileFeatureLayer to make it easier for the users to find.
- Added OpenStreetMapsZoomLevelSet class.
- Added WrappingMode property to support map wrapping past the dateline.
- Added LabelAllLineParts property in TextStyle to label all parts of a MultiplelineShape.
- Added the enum PolygonLabelingLocationMode to improve the algorithm for labeling polygon.
- Added new class "SerializationHelper" for help to deserialize objects accross different versions of Map Suite.
- Obsoleted some methods in ManagedProj4Projection according to Proj4Projection class.
- Fixed a bug where the IconStyle didn't display any labels when user didn't set icon images.
- Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
- Fixed the bug that ViewState is so large because of Map.MapTools
- Removed some Features of OpenLayers 2.8 Deprecated compared to 2.7
- Fixed the Memory leak when refreshing the markers again and again
- Fixed the bug it will be displacement when using VirtualEarthOverlay
- Fixed the bug that the marker in InMemoryMarkerOverlay and FeatureSourceMarkerOverlay are cut off
- Added the backGroundColor for Marker Text
- Fixed the bug that the text for marker is cut off
- Fixed the bug that assigning rotation angle to markers
- Fixed the bug that VS2010 WebEdition project is unable to work normally.
- Added ClusterMarkerStyle to cluster the markers and improve the MarkerOverlay performance.
- Improved the bad performance when MarkerOverlay works with huge markers
- Map crash after long idle time
- Fixed the problem not encrypted for some private functions
- Optimized the retrieving twice for MSSqlFeatureSource geometry column.
- Provided support for VS2010 and samples.
- Fixed a rounding bug in GetPointOnALine API of LineShape.
- Fixed an issue when using a Chinese font
- Functions of MSSqlServer2008FeatureSource or Layer run to error in some specified culture.
- Bad performance with SQLServer2008 when using Geography type and large data size.
- Fixed an issue when using the UpdateColumnName API in dbf module.
- Fixed an issue throwing exception when calling BuildIndex in Turkey enviroment.
- Point Placement Affected by Label Length
- WmsRasterLayer cannot work when deserialized
- Support .NET 3.5 Client Profiler
- Implemented INotifyCollectionChanged, INotifyPropertyChanged interface in GeoCollection
- Replaced the Proj4Projection into ManagedProj4Projection used internally
- Fixed the issue the RasterLayer is not drawn in the PrinterGeoCanvas.
- Added OpenStreetMapLayer to support OpenStreetMap
- Added Managed GeoTiffRasterSource
- Added GetFeatureInfo functions for WmsRasterLayer
- Enhanced performance for GdiPlusRasterLayer
- Added ClusterPointStyle
- Added DrawingProgressChanged event
Version 4.0.40.0
Release date: 6/15/2010
- Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details.
- Fixed issue with the ScaleTo API in BaseShape when called by a Rectangle Shape.
- Fixed issue where an exception would be thrown when calling BuildIndex in a Turkish enviroment.
- Fixed issue when using the UpdateColumnName API in DBF module.
- Fixed issue involving use of Chinese fonts
- Fixed a rounding bug in the GetPointOnALine API of LineShape.
- Some minor API changes. See the API change log for complete details.
Version 4.0.0.17
Release date: 5/21/2010
- Fixed issue where DrawingArea property was no longer present in PdfGeoCanvas.
Version 4.0.0
Release date: 5/1/2010
ThinkGeo.MapSuite.Web Namespace:
- Many core enhancements and additions as itemized here.
- Added Visual Studio 2010 "How Do I?" sample application solution.
- Added animated panning.
- Added measurement tools.
- Added Clustering Marker Strategy.
- Added method where markers are rendered on GetBitmap.
- Added the ability to change the title of the OverlaySwitcher panel.
- Added new events for draggable markers, such as BeforeDrag, Dragging, and EndDrag
- Added new key modifier options for TrackZoom, such as Shift, Ctrl, etc.
- Added ContextMenu that can be wrapped at the edges of the map.
- Added Pan behavior on the HighlightOverlay.
- Added auto refresh for WMSOverlay.
- Added Serializable attribution to SimpleMarkerOverlay.
- Added WrapdateLine for LayerOverlay and WmsOverlay.
- Added CallBackResult to support asynchronous refresh.
- Added support for ContextMenus with sub-levels.
- Added OSMOverlay to support an Open Street Map server.
- Added ArcGISRestServerOverlay to support ArcGIS Rest Server.
- Added a property that specifies if the embedded resources can be copied to the website in runtime.
- Added controller about how to specify if the web.config can be integrated in runtime.
- Exposed more client functionality accessible via JavaScript.
- Removed the exception when using the DefaultOverlay and CustomOverlay together.
- Fixed issue with deploying the map to IIS 7.5 when using DefaultPool.
- Fixed issue with rendering BaseOverlayTitle and OverlaySwitcher Tile in runtime.
- Fixed issue where Virtual Earth maps go blank when you resize the map.
- Fixed block of OnClientEditEnd event when the shape is not changed.
- Fixed the IE7 "Operation Aborted" error with Virtual Full PostBack
- Fixed the memory leak when refreshing markers repeatedly.
- Fixed issue where Virtual Earth Bird's Eye imagery does not show.
- Several API additions, plus one breaking change. See the API change log for complete details.
- Updated the API documentation.
- Added additional helper methods to the GeoCollection class.
- Added better support for labeling with Asian characters.
- Added support for Google Static Maps API v2.
- Added simple support for Yahoo Maps.
- Added support for heat map layers.
- Added support for 100% managed proj Projection Library.
- Added direct support for Map Shapes.
- Added API to modify the column name in ShapeFileFeatureSource and ShapeFileFeatureLayer.
- Added new API BuildIndex for MultipleShapeFileFeatureLayer
- Included GraticuleLineLayer support and a sample application for it.
- Enhanced the MultiShapeFileFeaturesLayer class to allow you to use files in multiple folders.
- Enhanced the distance measuring method to use the Haversine formula.
- Improved GeoCache performance.
- Updated the PostgreSQL Assembly versions.
- Exposed the DBaseFile class library.
- Exposed the disk-based RTree Spatial Index.
- Split up the Map Suite MergeModule into smaller and more manageable pieces.
- Fixed issue where GetCenterPoint using NTS would return an invalid value when the polygon's width and height is 0.
- Fixed issue regarding GetBoundingBox of GroupLayer.
- Fixed issue where GetAllColumns also returns the Geometries column.
- Many API additions. See the API change log for complete details.
Version 3.1.299
Release date: 11/16/2009
- Fixed issue where Web Edition did not work under IIS 7.0's Integrated Mode.
- Fixed issue with a client exception in Firefox involving session_georesource.axd.
- Fixed issue with JavaScript that would occur when changing the drawing mode in Firefox.
- Some minor API additions. See the API change log for complete details.
- Fixed issue where SaveToProjection is incorrect for some data.
- Fixed issue with the DecimalDegreesHelper API GetDecimalDegreeFromDegreesMinutesSeconds.
- Fixed caculation issue in DecimalDegreeHelper.GetDistanceFromDecimalDegrees when passing particular data.
- Fixed issue where an exception is thrown for TAB files when the column name starts with an underscore(_).
Version 3.1.273
Release date: 10/22/2009
- Upgraded to OpenLayers 2.8.
- Fixed event conflict when using DraggableMarker and MapClick event.
- Fixed issue regarding event that needed to be reaised in MasterPage.
- Fixed issues where the map would turn blank after a postback in Firefox.
- Fixed issue with Tracking/Editing shapes in Internet Explorer 8.
- Added Haversine formula to calculate distance.
- Added DrawException method to draw exceptions rather than throwing them in the Overlay and Layer.
- Added IndexedInMemoryFeatureLayer Class.
- Added ReadOnly logic to ClearCache and DeleteTile methods.
- Added the schema supported in PostgreFeatureSource.
- Added API overloads for GetFeaturesByColumnValue method.
- Added API to detect the feature type in FeatureSource.
- Added API BuildIndex in InMemoryFeatureLayer.
- Enhanced the Sql2008FeatureSource, PostgreFeatureSource and OracleFeatureSource by adding one event ExecutingSqlStatement.
- Extended the KeyColor from one color to an array of colors or a range of colors.
- Fixed a memory leak when calling OpenAllLayers multiple times.
- Fixed issue where ApplyUntilZoomLevel doesn't work right when using CustomZoomLevel.
- Fixed OutofMemory exception issue in WFSFeatureSource.
- Fixed issue where SaveToProjection in ShapeFileFeatureSource would throw an out of memory exception.
- Fixed issue with the Stream_Loading event in ShapeFileFeatureSource.
- Fixed issue with obfuscation in autobuild.
- Fixed issue where the WMS cannot work properly when the network is unavailable.
- Fixed issue where GetRandomColor always get the same color.
- Fixed issue where CloneDeep of InMemoryFeatureSource does not work.
- Fixed issue where InmemoryFeatureSource cannot be serialized correctly.
- Fixed issue where you could not parse the parent layer in a WMS server.
- Fixed issue where an OutOfMemory error occurs while drawing.
- Fixed issue with support for Geography type data in MsSqlFeatureSource.
- Fixed issue with the GetFeaturesInsideBoundingBox method of MultipleShapeFileFeatureSource.
- Fixed issue where GetCenterPoint using NTS will return an invalid value when the polygon's width and height is 0.
- Fixed issue regarding thrown exception ORA-00936: Missing Expression.
- Fixed issue where GetPointOnALine returns the wrong value.
- Fixed issue where GdiPlusRasterLayer has a black line in tile mode.
- Fixed issue with the GetFeatureById API in WfsFeatureLayer.
- Fixed very low performance issue with GetColumnsCore.
- Fixed issue with missing tag information in InMemoryFeatureLayer.
- Fixed non-serializable issue for WFSFeatureLayer.
- Fixed issue where an exception was thrown when building an index for an empty shape file.
- A number of API changes. See the API change log for complete details.
Version 3.1.182
Release date: 7/23/2009
- Added client cache on the client side for improved loading performance.
- Added a property to disable multithreading in LayerOverlay to make debugging easier.
- Fixed issue with the FeatureSourceMarkerOverlay.
- Fixed issue where a sub-class of Map would not work correctly.
- Fixed issue where the FDO Extension would throw an exception when multi-threading.
- Added some APIs for ScaleBar in order to implement the same functionality as in ScaleLine.
- Fixed issue with setting a different DPI for canvas.
- Fixed issue where the Matrix system did not consider the MapUnit.
- Fixed issue where the OverrideMode did not work correctly for the ShapeFileFeatureLayer.SaveToProjection API.
- Fixed issue where an exception would be thrown when using a MaskBrush for the ScaleBar.
- Fixed issue where bool field cannot be updated in the DBF.
- Fixed the Out of Memory Exception thrown when calling the ShapeFileFeatureLayer.SaveToProjection API on very large shape file data.
Version 3.1.124
Release date: 5/26/2009
- Added MarkerDragged event on the server side.
- Added support for ASP.NET MVC.
- Added a search engine to the "How Do I?" sample apps browser.
- Added JavaScript library cache support.
- Added simple styles for EditionOverlay support.
- Added WFS support.
- Enhanced track shape functionality.
- Enhanced cache pre-generation extension.
- Optimized client printing.
- Optimized multi-language support.
- Bugs fixed:
- Fixed match issue when using a Virtual Earth overlay.
- Fixed issue involving draggable markers.
- Fixed issue with session saving support in SQLServer.
- Fixed issue when working with Callback.
- Added an API to CheckForUnSupportedShapeTypes(string shapeFilePath).
- Added support for a Polygon record that contains 0 parts.
- Added an overload for BuildIndexFile.
- Added ExecuteQuery support for Postgre.
- Added property to show whether the assembly is the Full Version or Evaluation Version.
- Added an overload to CreateShapeFile so that user can choose whether they want to override.
- Added polygon simplification to AreaShapes.
- Added line simplification to LineShapes.
- Added obsolete to the AllowSpline property in text style.
- Added GetFirstGeometryType in Postgre, Oracle and SQL layers.
- Added "Simplify" sample application.
- Added an overload to GetFeaturesNeareastTo with a distance limitation.
- Added documentation for DashPattern.
- Added ToGdiPlusColor method in GeoColor.
- Added a way to build a spatial index based on another projection, not using a feature list.
- Added DPI support for the GeoCanvas.
- Improved the TIFF quality for GeoTiffRasterLayer.
- Changed the logic of GetZoomLevelForDrawing by considering the IsActive.
- Changed the proj4.GetEpsgParameters(srid) method from instant to static.
- Changed the Layer.IsVisible to virtual.
- Checked the IdFieldColumn for all spatial databases like Postgre, Sql2008 and Oracle.
- Fixed issue when modifying the inner logical of DbfColumn constructor.
- Fixed issue where GeoTiff was not supported.
- Fixed issue where the parameter name is wrong for the postgreFeatureLayer's constructor.
- Fixed issue where TextStyle.Format did not work.
- Fixed issue involving uppercase conversion when executing SQL in shape file feature source.
- Fixed issue with GetFeaturesForDrawing logic.
- Fixed issue with TextStyle.DrawCore DPI.
- Fixed issue where RasterLayer does not work when the DPI is not 96.
- Fixed issue where a Postgre Layer will throw "Object reference not set to an instance of an object" exception.
- Fixed issue involving the first Rotation when setting Rotation projection.
- Fixed issue where PointStyle.DrawSample() did not work.
- Fixed issue where the drawing order is not correct when adding multiple types of features to one feature layer.
- Fixed issue in GetFeaturesByColumnValue.
- Fixed issue where custom column did not work for the spatial query methods.
- Fixed issue where the gdiPlusGeoCanvas.DrawCircle() result is not correct.
- Fixed issue where ExecuteQuery did not work properly.
- Improved some exception descriptions.
- Fixed issue where featureLayer.Columns exists, but the featureSource.Columns property does not.
- Fixed issue with GroupLayer display order.
- Fixed issue where GetRandomGeoColor was missing.
- Fixed issue involving sorting classBreaks internally.
- Fixed issue involving support for all other types like (PolyM) for ShapeFile Layer.
- Fixed issue involving exposure of static API from ShapeFileFeatureSource to ShapeFileFeatureLayer.
- Fixed issue where the Transparency property does not work in RasterLayer.
- Fixed issue where DotDensityStyle was not drawing after CloneDeep.
- Fixed issue in Map Suite Explorer.
- Fixed issue where creating a shapeFileLayer by streamloading event would throw an exception in layer.close().
- Fixed issue involving consideration of the DoNotDraw property or FeaturesToExclude.
- Fixed issue where TestLayerStyle.DrawSample did not work properly with the haloPen.
- Fixed issue where GetBoundingBoxOfItems did not work properly.
- Fixed issue involving label drawing even if the line was visible on the screen.
- Fixed issue where the CustomFieldFetch event did not work in a ShapeFileFeatureLayer.
- Fixed issue where GeoPen does not act on symbol Diamond, Diamond2, Star or Star1.
- Fixed issue where some shape files cannot build an index.
- Fixed issue where GeoPen and GeoBrush constructors did not work.
Version 3.1.16
Release date: 2/6/2009
- Added new feature: Draggable markers.
- Resolved issue with zooming out after doing a postback.
Draggable markers:
The code to implement a draggable marker is quite simple. An example:
SimpleMarkerOverlay markerOverlay = new SimpleMarkerOverlay("MarkerOverlay"); markerOverlay.DragMode = MarkerDragMode.Drag; markerOverlay.Markers.Add(new Marker(0, 0, new WebImage(21, 25, -10.5f, -25f))); Map1.CustomOverlays.Add(markerOverlay);
- Added an API(ZoomToOffsetPoint) in ExtentHelper.
- Added Overloads GetFeaturesInsideBoundingBoxCore and GetFeaturesOutsideBoundingBoxCore.
- Added a more descriptive message for a ShapeFile validation.
- Added SaveToProjection in ShapeFileFeatureSource and ShapeFileFeatureLayer.
- Added a protected virtual property for the cached featureSourceColumns.
- Added an API in the FeatureSource to refresh the cached columns.
- Added the API CheckForUnSupportedShapeTypes(string shapeFilePath).
- Changed the logic to use the InMemoryFeatureSource and InMemoryFeatureLayer.
- Resolved an issue with style.DrawSample.
- Resolved System.AccessViolationException when the map is redrawn.
- A number of API additions. See the API change log for complete details.
Version 3.1.0
Release date: 1/22/2008
- Add X64 OS support.
- Added support for session serialization.
- Added support for a client zoomlevels setting mechanism.
- Added support for changing a shape's style when editing.
- Improved shape edit settings.
- Improved APIs. See the API change log for complete details.
- Bugs fixed:
- Display error when using different regions.
- Can't use the pageLoad default client function on an .aspx page.
- Exception description resource error.
- Fixed a memory leak when navigating a map at the client side.
- Synchronized non-baseOverlay visibility between client and server side.
- Double-click event won't trigger when the MouseMapTool is enabled.
- Added a parameter check to the Projection class.
- Added a CustomZoomLevels collection to the ZoomLevelSet to allow for custom zoom levels.
- Added a more descriptive exception message if a PolygonShape or MultiPolygonShape does not pass the validation test.
- Added HasProjectionText and ProjectionText properties to RasterSource and RasterLayer.
- Added validation checks on each member of the QueryTools to ensure that the Layer has been opened.
- Added a new API for getting features based on the value in a column.
- Added another parameter to BeginDrawing in GeoCanvas.
- Added ExecuteSqlQuery and CanExecuteSqlQuery methods to QueryTools and FeatureSource.
- Added two overloads for the method LineShape.GetLineOnLine.
- Added encoding tests.
- Added MrSid support in 64-bit environments.
- Created JPEG2000RasterLayer/JPEG2000RasterSource to make it easier to load JPEG2000 images.
- Provided an API in ShapeFileFeatureSource and ShapeFileLayer.
- Updated the documentation for class name changes and for classes that did not previously have documentation.
- Changed PathFileName to PathFilename.
- Changed the ReadMe to Readme.
- Changed the MapSuiteCore class to take advantage of re-projecting an array of points.
- Changed the internalFeatures from a Dictionary to a GeoCollection.
- Modified ShapeFileFeatureSource.ExecuteSqlQuery() to throw exception if filename is longer than 8 characters.
- Enhanced the Projection classes and members.
- Improved performance in GdiPlusRasterLayer.
- Improved the Union Sample logic.
- Improved the exception description for Layer.QueryTools/Layer.EditTools.
- Improved the documentation for EditTools.Union.
- Improved speed of spatial queries with a polygon-based layer when using a MultiPolygonShape as the target shape.
- Improved speed of the Proj4Projection class by removing the locking code.
- When building an index, all features are now loaded into memory.
- Fixed missing overload for static method CreateSimpleAreaStyle.
- Fixed ZoomIn bug.
- Fixed the PointStyle, AreaStyle and LineStyle DrawSample methods so that they return the sample in the middle of the image.
- Fixed an outstanding issue with style.DrawSample.
- Reviewed all of the the Try...Catch code.
- Resolved issue where the static function BuildRecordIdColumn required a spatial index on the Layer first.
- Resolved issue where a System.AccessViolationException would be thrown when redrawing the map.
- Resolved issue with WMS when using a Web Proxy.
- Resolved issue where dragging two raster layers to Explorer throws an exception.
- Resolved issue when a Layer's zoom level did not work under a projection other than WGS 84.
- Resolved issue with ScalebarAdornmentLayer.
- Resolved issue with RectangleShape.ExpandToInclude.
- Resolved issue where WmsService would not work with HTTPS/SSL.
- Resolved issue where mapEngine.OpenAllLayers() would not open an AdornmentLayer.
- Resolved issue where the Geographic.Unit and DistanceUnit in BaseShape.Buffer() were reversed.
- Resolved issue with BuildIndex where getting all features would not work.
- Resolved issue where QueryTools.GetFeaturesContaining would not work when features are in the transaction buffer.
- Reintroduced the AreaShape.GetCrossings method (which was previously present in Map Suite 2.0).
- Reintroduced support for raster files (ECW, MrSid, BMP, etc.) in Map Suite Explorer.
- Removed the obsolete target framework for .NET 2.0.
- A number of API additions and changes. See the API change log for complete details.
