Map Suite Silverlight Edition FAQ Layers & FeatureSources
From ThinkGeo Wiki
| Rate This Article | |
| Current rating: 0% (0 votes)
You need to enable Javascript to vote
How do I efficiently display a subset of a shape file without splitting it?
For more information and a real-world example, please see the Map Suite discussion forum post at:
Forum Post
How do I display highways and local roads using different symbols from the same shape file?
Forum Post
Forum Post
How do I draw a north arrow on my map?
We also added new designs of compass in smaller version. See the attached file: Rotating Compass New Smaller Designs.zip.
How do I display graphs and charts on the map?
In our “How Do I” apps, there is sample app that shows how to add graphs to the map using the ZedGraph library. In this project, using the same data, the US cities, we elaborate a little bit on the pie chart. You will see how to add some gradient colors to the chart, how to label the different pie slices, how to add a title etc. Zedgraph is a truly massive library for graphics and Pie chart is only one type of chart among many others. As you can add pie charts to your map, you can also add bar charts, trend charts etc. I suggest you check out this site for more info on ZedGraph
http://zedgraph.org/wiki/index.php?title=Main_Page
With Map Suite, you have the whole ZedGraph API available with an easy interface to add the graphs to the map.
For this project, in addition to the MapSuiteCore.dll, you will also need the ZedGraph.dll and ZedGraphStyleExtension.dll references.
We will have several projects showing how to integrate other types of charts to your map.
How do I add a watermark to the map?
How do I encrypt a shape file for security?
How do I get geometry data from the server using WCF in Silverlight?
How do I display a scale bar using custom units?
How can I show my own logo on the map?
How do I display heat map?
How can I load an image from a stream rather than a file?
How can I draw KML on the map?
How do I display latitude and longitude graticule lines?
How can I display a legend on my map?
How do I show a mini map?
How do I display multi geo-raster files as one layer?
How do I work with multi index files?
How do I display point data from an OLE DB complied data source?
In this project, we create the class OledbPointFeatureSource inheriting from FeatureSource and OledbPointFeatureLayer inheriting from FeatureSource.
How do I create a numbered grid for a given extent?
How do I draw a north facing arrow when using rotation?
Displaying the North Arrow:
How to use a common FeatureSource for two different Overlays?
How to edit the geometry of a shapefile?
How to edit attribute of a shapefile?
How to create GRID?
Yes. Starting with build 5.0.87.0 of Map Suite, you can add isolines to your applications with Map Suite -- please see the code sample linked above. For the uninitiated, isolines are a way to visualize breaks between different groups of data such as elevation levels, soil properties, or just about anything else you can imagine. The above code sample also shows the various steps in creating isolines, including the gathering of point data, creating a grid using interpolation, and finally, picking your isoline break levels. We also quickly dive into some more advanced options such as generating isolines on the fly. To bring this all together, check out our
instructional video that will walk you through the process of setting up and working with isolines in Map Suite.
