Map Suite Desktop Edition FAQ Background Maps (Google, Bing, etc.)
From ThinkGeo Wiki
| Rate This Article | |
| Current rating: 0% (0 votes)
You need to enable Javascript to vote
Contents |
How do I reprojected a decimal degrees shape file to display on Google Maps?
Sample:Shapefile to Google Map
How do I show GPS data in decimal degrees on Google Maps?
Sample:GPS to Google Map(Desktop)
Today we have the Desktop version of the Web project “GPS to Google”. In this project, we show how to display on Google Map point data coming from some GPS reading in Geodetic (Longitude/Latitude). It also shows how to set the extent of the map so that it is centered on the GPS point.
How do I show a great circle line on Google Maps?
Sample:Great Circle with Google Map
How do you display OpenStreetMap imagery?
How do I show a mini map on Google Maps?
Sample:Mini map with Google Map
