6.0.0.0 [2015/08/20 03:08] |
6.0.0.0 [2015/08/20 03:08] (current) |
+ | ====== 6.0.0.0 ====== | ||
+ | Several Merge Modules are supplied to assist you in deploying all of our required dependencies. You can find them in the directory below. | ||
+ | ===== Public Release Version (6.0.0.0)===== | ||
+ | *\Developer Reference\Merge Module\MapSuiteEcwX64.msm | ||
+ | *\Developer Reference\Merge Module\MapSuiteEcwX86.msm | ||
+ | *\Developer Reference\Merge Module\MapSuiteGeoTiffX64.msm | ||
+ | *\Developer Reference\Merge Module\MapSuiteGeoTiffX86.msm | ||
+ | *\Developer Reference\Merge Module\MapSuiteMrSidX64.msm | ||
+ | *\Developer Reference\Merge Module\MapSuiteMrSidX86.msm | ||
+ | *\Developer Reference\Merge Module\MapSuitePrjHelperX64.msm | ||
+ | *\Developer Reference\Merge Module\MapSuitePrjHelperX86.msm | ||
+ | *\Developer Reference\Merge Module\MapSuiteProj4ProjectionX64.msm | ||
+ | *\Developer Reference\Merge Module\MapSuiteProj4ProjectionX86.msm | ||
+ | *\Developer Reference\Merge Module\MapSuiteFdoExtensionX86.msm | ||
+ | *\Developer Reference\Merge Module\MapSuiteFdoExtensionX64.msm | ||
+ | *\Developer Reference\Merge Module\VC_User_CRT71_RTL_X86_---.msm | ||
+ | *\Developer Reference\Merge Module\VC_User_STL71_RTL_X86_---.msm | ||
+ | Note: The main assemblies (such as MapSuiteCore.DLL, NetTopologySuite.DLL and GeoAPI.dll) are not included in the Merge Modules, your project should automatically reference them and pull in these assemblies. | ||
+ | MapSuiteGeoTiffX64.msm and MapSuiteGeoTiffX86.msm are not required if the GeoTiffRasterSource's LibraryType is ManagedLibTiff(By Default). | ||
+ | MapSuiteProj4ProjectionX64.msm and MapSuiteProj4ProjectionX86.msm are not required if Proj4Projection's MemoryMode is ManagedProj4Projection(By Default). | ||
+ | MapSuiteFdoExtensionX86.msm and MapSuiteFdoExtensionX64.msm are not required if FdoExtension is not used. | ||
+ | =====Development Branch Revision (6.0.164.0)===== | ||
+ | *\Developer Reference\Merge Module\MicrosoftSqlServerSpatialX86.msm* | ||
+ | *\Developer Reference\Merge Module\MicrosoftSqlServerSpatialX64.msm* | ||
+ | *\Developer Reference\Merge Module\Microsoft_VC100_CRT_x64.msm* | ||
+ | *\Developer Reference\Merge Module\Microsoft_VC100_CRT_x86.msm* | ||
+ | *\Developer Reference\Merge Module\MapSuiteGeoRasterProjectionX86.msm** | ||
+ | *\Developer Reference\Merge Module\MapSuiteGeoRasterProjectionX64.msm** | ||
+ | *\Developer Reference\Merge Module\MapSuiteEcwX64.msm** | ||
+ | *\Developer Reference\Merge Module\MapSuiteEcwX86.msm** | ||
+ | *\Developer Reference\Merge Module\MapSuiteGeoTiffX64.msm** | ||
+ | *\Developer Reference\Merge Module\MapSuiteGeoTiffX86.msm** | ||
+ | *\Developer Reference\Merge Module\MapSuiteMrSidX64.msm** | ||
+ | *\Developer Reference\Merge Module\MapSuiteMrSidX86.msm** | ||
+ | *\Developer Reference\Merge Module\MapSuiteProj4X64.msm** | ||
+ | *\Developer Reference\Merge Module\MapSuiteProj4X86.msm** | ||
+ | *\Developer Reference\Merge Module\MapSuiteFileGeoDatabaseX64.msm*** | ||
+ | *\Developer Reference\Merge Module\MapSuiteFileGeoDatabaseX86.msm*** | ||
+ | *\Developer Reference\Merge Module\MapSuiteOracleDependenciesX64.msm**** | ||
+ | *\Developer Reference\Merge Module\MapSuiteOracleDependenciesX86.msm**** | ||
+ | MicrosoftSqlServerSpatialX86.msm*, MicrosoftSqlServerSpatialX64.msm*, Microsoft_VC100_CRT_x86.msm* and Microsoft_VC100_CRT_x64.msm* are always required. | ||
+ | //*** From Build 6.0.35.0 in Development Branch, the merge modules can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteSqlServerTypesMergeModule2012-07-11.zip//** | ||
+ | //**** From Build 6.0.360.0 in Development Branch, the merge modules can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteUpdatedMergeModules2013-05-08.zip//** | ||
+ | //***** From Build 6.0.103.0 in Development Branch, the merge modules can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteFileGeoDatabaseMergeModules2012-08-24.zip//** | ||
+ | //****** From Build 6.0.200.0 in Development Branch, the X86 merge module can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteOracleDependenciesMergeModuleX862012-11-29.zip//** | ||
+ | //****** From Build 6.0.200.0 in Development Branch, the X64 merge module can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteOracleDependenciesMergeModuleX642012-11-29.zip//** | ||
+ | //******* From Build 6.0.299.0 in Development Branch, the X86 merge module can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteVC100_DebugCRTMergeModuleX862013-03-15.zip//** | ||
+ | //******* From Build 6.0.299.0 in Development Branch, the X64 merge module can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteVC100_DebugCRTMergeModuleX642013-03-15.zip//** | ||
